Inleiding
The RAM is a place gathering all the data from the laptop. The quality of a RAM determines the running speed of a computer. This guide introduced the method of RAM replacement.
Wat je nodig hebt
Stap 1 Back Cover
Voorzichtig: stap 1 komt van een handleiding die in bewerking is.
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
Remove the RAM from the device.
Repeat this for second RAM stick
