Inleiding
This guide introduces how to remove the battery from Dell Latitude E7470. The laptop comes with different battery configurations. While this guide shows how to replace a standard capacity battery, the procedure is similar when replacing the extended capacity battery.
Wat je nodig hebt
Stap 1 Back Cover
Voorzichtig: stap 1 komt van een handleiding die in bewerking is.
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
9 andere personen hebben deze handleiding voltooid.
