Ga door naar hoofdinhoud
Dell Latitude E7440 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: stap 1, afbeelding 1 van 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: stap 2, afbeelding 1 van 3 Dell Latitude E7440 Battery Replacement, Release the battery: stap 2, afbeelding 2 van 3 Dell Latitude E7440 Battery Replacement, Release the battery: stap 2, afbeelding 3 van 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: stap 3, afbeelding 1 van 1
    • Lift the battery by the top, away from the laptop body.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Akash Kedia
1.397 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G5, White Winter 2019 Lid van Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Leden
2 opmerkingen
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - Antwoord
Any recommended site to buy original battery?
Razin Ahmed - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 69
Altijd: 5,310
