Ga door naar hoofdinhoud
Dell Latitude E7250 RAM Replacement
Wat je nodig hebt
  1. Dell Latitude E7250 RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Latitude E7250 RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: stap 2, afbeelding 1 van 3 Dell Latitude E7250 RAM Replacement, RAM: stap 2, afbeelding 2 van 3 Dell Latitude E7250 RAM Replacement, RAM: stap 2, afbeelding 3 van 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: stap 3, afbeelding 1 van 3 Dell Latitude E7250 RAM Replacement: stap 3, afbeelding 2 van 3 Dell Latitude E7250 RAM Replacement: stap 3, afbeelding 3 van 3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 56
Altijd: 4,767
