Ga door naar hoofdinhoud
Dell Latitude E6540 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: stap 1, afbeelding 1 van 2 Dell Latitude E6540 Battery Replacement, Hibernate your laptop: stap 1, afbeelding 2 van 2
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: stap 2, afbeelding 1 van 2 Dell Latitude E6540 Battery Replacement, Unlock the battery: stap 2, afbeelding 2 van 2
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: stap 3, afbeelding 1 van 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: stap 3, afbeelding 2 van 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: stap 3, afbeelding 3 van 3
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install the new battery: stap 4, afbeelding 1 van 3 Dell Latitude E6540 Battery Replacement, Install the new battery: stap 4, afbeelding 2 van 3 Dell Latitude E6540 Battery Replacement, Install the new battery: stap 4, afbeelding 3 van 3
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: stap 5, afbeelding 1 van 1
    • Turn the computer on and plug the charger in.
Eindstreep
7 andere personen hebben deze handleiding voltooid.
Nick
88.899 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.539 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 8,159
