Inleiding
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
Wat je nodig hebt
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
Één andere persoon heeft deze handleiding voltooid.
