Ga door naar hoofdinhoud
Dell Latitude E6510 WWAN Card Replacement
Wat je nodig hebt
  1. Dell Latitude E6510 WWAN Card Replacement, WWAN Card: stap 1, afbeelding 1 van 2 Dell Latitude E6510 WWAN Card Replacement, WWAN Card: stap 1, afbeelding 2 van 2
    • Remove the 8mm screw in the middle from the laptop with the J1 screwdriver.
    • Then slide the back plate off.
  2. Dell Latitude E6510 WWAN Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the antenna wires from the WWAN card using a plastic opening tool.
    • Use the same Phillips screwdriver to remove the screw holding the WWAN card in place.
    • The WWAN card is missing in this model.
Conclusie
Kolin Doyle
500 Reputatie
4 handleidingen geschreven
Baylor, Team S8-G4, Johnson Fall 2017 Lid van Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 Lid
2 opmerkingen
This article is incorrect. The slot being showed in the diagram is for a WWAN, which is used for connecting to a a cellular network (3G, 4G, LTE, etc). The actual wifi card is tucked under the gray plastic cover at the top right (looking at the first photo) above the CPU fan.
Jason - Antwoord
Holy !&&* this is misleading. All of this “Kolin Doyle” person’s guides are idiotic and basic, everybody knows how to take a %#*@ battery out of a laptop! And as Jason said, the guide is totally incorrect, that’s the wrong %#*@ slot for gosh sake; that slot is for a WWAN card that allows connecting to a cellular network, the WiFi card is under the plastic cover on the right, above the heatpipes, and you can even see an antenna cable! Please, mods, delete this incorrect guide and the rest of the guides this person has published; the Latitude e6510 is the easiest laptop to service that I personally own and this guy is making it look hard.
Alex Matthiessen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 2,245
