Ga door naar hoofdinhoud
Dell Latitude E6510 Heat Sink Replacement
Wat je nodig hebt
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: stap 1, afbeelding 1 van 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: stap 1, afbeelding 2 van 3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: stap 1, afbeelding 3 van 3
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: stap 2, afbeelding 1 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 2, afbeelding 2 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: stap 3, afbeelding 1 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 3, afbeelding 2 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 3, afbeelding 3 van 3
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: stap 4, afbeelding 1 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 4, afbeelding 2 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: stap 6, afbeelding 1 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 6, afbeelding 2 van 3 Dell Latitude E6510  Heat Sink Replacement: stap 6, afbeelding 3 van 3
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 955
