Wat je nodig hebt
Make sure all external components are removed from the device( ie. USBs, power cords, network cables, headphones, etc.) and the device is powered off.
Slide the battery release latches into the unlock position. Then, rotate the outer edge of the battery upward and remove from the system.
After removing the battery, remove the screws that secure the base cover to the computer, then lift the base cover and remove it from the computer.
Pry the securing clips away from the memory module until it pops-up and remove the memory module from its connector on the system board.
With your new memory, insert the memory into the memory socket, then press the securing clips to secure the memory module to the system board.
Reassemble your device by performing the instructions above in reverse order.
Één andere persoon heeft deze handleiding voltooid.
