Ga door naar hoofdinhoud
Dell Latitude E6420 Backplate Replacement
Wat je nodig hebt
  1. Dell Latitude E6420 Backplate Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Latitude E6420 Backplate Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Backplate Replacement: stap 2, afbeelding 1 van 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: stap 3, afbeelding 1 van 2 Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: stap 3, afbeelding 2 van 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Backplate Replacement: stap 4, afbeelding 1 van 2 Dell Latitude E6420 Backplate Replacement: stap 4, afbeelding 2 van 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Backplate Replacement, Backplate: stap 5, afbeelding 1 van 2 Dell Latitude E6420 Backplate Replacement, Backplate: stap 5, afbeelding 2 van 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Backplate Replacement: stap 6, afbeelding 1 van 2 Dell Latitude E6420 Backplate Replacement: stap 6, afbeelding 2 van 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Madysen Eames
1.528 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Lid van UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 34
Altijd: 1,905
