Ga door naar hoofdinhoud
Dell Latitude E6330 Speakers Replacement
Wat je nodig hebt
  1. Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: stap 1, afbeelding 1 van 2 Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: stap 1, afbeelding 2 van 2
    • Take out the battery by pulling the tabs.
    • Unscrew 2 screws and remove the hard drive (Phillips Head 1 2.5mm x 5mm).
  2. Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: stap 2, afbeelding 1 van 2 Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: stap 2, afbeelding 2 van 2
    • Press and remove the SD card protector.
    • Press and remove the pull tab on DVD Drive.
  3. Dell Latitude E6330 Speakers Replacement, Removing the Backplate: stap 3, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: stap 3, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: stap 3, afbeelding 3 van 3
    • Unscrew the five screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the backplate by pulling from the battery to the front.
  4. Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: stap 4, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: stap 4, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: stap 4, afbeelding 3 van 3
    • Remove the track pad wire by carefully pulling up.
    • Flip the laptop over to top.
    • Remove the bezel from the keyboard by prying under the bezel and unclipping it.
    • Pull the bezel from the track pad to the screen to remove it.
    • The wire is fragile, handle with care.
  5. Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: stap 5, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: stap 5, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: stap 5, afbeelding 3 van 3
    • Unscrew the three screws (Phillips Head 1 2mm x 3mm).
    • Unclip the keyboard wire harness, then slide the wire towards the screen to remove it.
    • Unclip the trackpad wire harness, sliding the wire towards the front of the laptop to remove it.
    • The wire harnesses are fragile and may break if the user adds too much pressure.
  6. Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: stap 6, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: stap 6, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: stap 6, afbeelding 3 van 3
    • Grab the wire harness and pull towards the track pad to remove it.
    • Remove the six screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the two screws (Phillips Head 1 2mm x 3mm).
  7. Dell Latitude E6330 Speakers Replacement, Removing Back-Palmrest Screws: stap 7, afbeelding 1 van 1
    • Remove the nine screws labeled P (Phillips Head 1 2.5 x 5mm).
    • Remove the two screws (Phillips Head 1 2 x 3mm).
  8. Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: stap 8, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: stap 8, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: stap 8, afbeelding 3 van 3
    • Insert spudger tool into crease of palmrest, prying in a downward motion.
    • Move along the edges of the palmrest, relieving all clips from laptop base.
    • Remove palmrest in a upwards motion.
  9. Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: stap 9, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: stap 9, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: stap 9, afbeelding 3 van 3
    • Remove the four screws to the speakers (Phillips Head 1 2.5 x 7mm).
    • Remove the speaker wire harness. Pull towards the track pad to remove it.
    • the wire is fragile, pull with care.
  10. Dell Latitude E6330 Speakers Replacement, Removing the Speakers: stap 10, afbeelding 1 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: stap 10, afbeelding 2 van 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: stap 10, afbeelding 3 van 3
    • Remove or move tape out of the way in order to release the wire.
    • Remove the speakers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 24
Altijd: 856
