Inleiding
This guide will help you replace your hard drive or upgrade to a SSD on the Dell Latitude E6320.
Make sure to fully turn off your laptop to prevent file corruption and minimise the risk of electric shocks!
Wat je nodig hebt
Slide the two latches each side of the battery outwards. You'll notice you've unlatched the battery from the chassis when you hear two clicks.
Remove the four Phillips #00 screws that secure the hard drive to the computer.
Find the outdent at the right side of the chassis, and pull it outward to release and slide out the hard drive.
Remove the Phillips #00 screw that secures the drive caddy to the hard drive.
To install your new hard drive and reassemble your device, follow these instructions in reverse order.
If you are replacing your exisitng HDD with a SSD, make sure to get a spacer.
Één andere persoon heeft deze handleiding voltooid.
