Wat je nodig hebt
Turn the laptop upside down
Slide the two switches to the outside until an orange marker appears.
Remove the battery by sliding it out
Remove the four M2x5 and 2 M2x8 screws with a Phillips PH0 screwdriver
Remove the bottom plate by gently lifting it from the empty battery space
Remove the RAM by pushing the metal parts slightly outward
The RAM will pop up and you can carefully slide it out
Remove the four M2x3 screws with a Phillips PH0 screwdriver
Slide the hard drive cradle out by pulling the plastic tab
Remove one M2x5 screw with a Phillips PH0 screwdriver
Use a blackstick to push out the optical drive and pull it further out by hand
Use a blackstick to carefully disconnect the battery connector
Gently guide the cable through the narrowed part and remove the battery that is held in place with double sided tape
Gently disconnect the white and black cable from the module with a blackstick
Remove one M2x3 screw with a Phillips PH0 screwdriver. The module will push up
Remove the module by sliding it out
Turn the laptop over and open the screen, carefully place the spudger under the top panel near the bottom left Ctrl key and push up
Gently remove the rest of the panel
Remove four silver screws with a Phillips PH0 screwdriver, slide the keyboard up a couple of millimetres then lift it up away from you to expose the ribbon cable
Disconnect the ribbon cable with the help of a spudger and remove the keyboard
Remove the M2x3 screw from the rear of the cowling using a Phillips #0 screwdriver
Remove the M2x8 screw from the inside of the cowling using a Phillips #0 screwdriver. Gently remove the cowling minding the catch on the bottom
Repeat the same steps on the opposite side to remove the second cowling
Één andere persoon heeft deze handleiding voltooid.
