Ga door naar hoofdinhoud
Dell Latitude E5500 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Latitude E5500 Wireless Card Replacement, Wireless Card: stap 1, afbeelding 1 van 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Wireless Card Replacement: stap 2, afbeelding 1 van 2 Dell Latitude E5500 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Wireless Card Replacement: stap 3, afbeelding 1 van 2 Dell Latitude E5500 Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • The wireless card is located near the front of the device, and is the expansion card with three antennas attached to it.
  4. Dell Latitude E5500 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the wires connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Wireless Card Replacement: stap 6, afbeelding 1 van 2 Dell Latitude E5500 Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Richard Harrison
805 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 18
Altijd: 1,238
