Ga door naar hoofdinhoud
Dell Latitude E5500 RAM Replacement
Wat je nodig hebt
  1. Dell Latitude E5500 RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: stap 2, afbeelding 1 van 2 Dell Latitude E5500 RAM Replacement: stap 2, afbeelding 2 van 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: stap 3, afbeelding 1 van 1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: stap 4, afbeelding 1 van 2 Dell Latitude E5500 RAM Replacement: stap 4, afbeelding 2 van 2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: stap 5, afbeelding 1 van 3 Dell Latitude E5500 RAM Replacement: stap 5, afbeelding 2 van 3 Dell Latitude E5500 RAM Replacement: stap 5, afbeelding 3 van 3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Conclusie
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Evan Eldridge
215 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 2,092
