Ga door naar hoofdinhoud
Dell Latitude E5470 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude E5470 Battery Replacement, Removing the Battery: stap 1, afbeelding 1 van 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift the battery away from the computer [3].
  2. Dell Latitude E5470 Battery Replacement, Remove the cable from the battery: stap 2, afbeelding 1 van 1
    • Unroute the cable from the routing channel [1] and remove the cable from the battery [2].
    • Connect the battery cable to the connector on the battery.
    • Route the battery cable through the routing channel on the battery
    • Insert the battery into the slot on the computer.
    • Tighten the screws to secure the battery to the computer.
    • Connect the battery cable to the connector on the system board
Conclusie
Marvin Romero
3.804 Reputatie
30 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.985 handleidingen geschreven
2 opmerkingen
I have this model but the problem is my battery. No batteries are currently installed. It seems that the battery cable for Latitude E5470 is faulty. How to confirm it's the cable?
Moutech - Antwoord
Same Here, Looks like the bios is Not accepting a non Dell battery. Any options to go round this Problem?
Peter Leest - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 46
Altijd: 1,025
