Wat je nodig hebt
Using your fingers or a pry tool, gently lift the cover from the device. If the device has been opened before, it should open easily from the top corner using your finger.
If it is a tight fit, a spudger can be used to gently pry open the cover. Place the spudger at the top corner to pry open.
Slide new WiFi card into the slot and reassemble the device by completing steps 1-6 in reverse order.
You might need to use tweezers to hold the cables in place as you connect the antenna to the WiFi card. A spudger can be used to gently press the connectors into place.
