Ga door naar hoofdinhoud
Dell Latitude E4300 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Latitude E4300 Hard Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Dell Latitude E4300 Hard Drive Replacement, Keyboard Docking Component: stap 4, afbeelding 1 van 1
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  5. Dell Latitude E4300 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Latitude E4300 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  6. Dell Latitude E4300 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Lift the keyboard panel to separate the component from the rest of the device.
  7. Dell Latitude E4300 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 2 Dell Latitude E4300 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 2 van 2
    • Unscrew the three screws located on the top of the component.
    • Lift the hard drive out of its holding in an outward motion and remove it from the device.
Conclusie
Ryan Blakey
172 Reputatie
2 handleidingen geschreven
3 opmerkingen
What!?! You can simple remove the hard drive by undoing two screws on the bottom of the laptop. Then you can remove the bezel from the laptop by undoing one more screw. It’s detailed in the service manual on the Dell website.
Rob Walter - Antwoord
I agree with Rob. It’s been made very easy. Pretty much the same as model E4310 here Dell Latitude E4310 Hard Drive Replacement.
Gwenole Capp - Antwoord
OK well, there’s no any need for such a BIG job actually! :)
Tarmo Tuljak - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 1,604
