Ga door naar hoofdinhoud
Dell Latitude E4300 Disk Drive Replacement
Wat je nodig hebt
  1. Dell Latitude E4300 Disk Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Disk Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Disk Drive Replacement: stap 3, afbeelding 1 van 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Dell Latitude E4300 Disk Drive Replacement, Keyboard Docking Component: stap 4, afbeelding 1 van 1
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  5. Dell Latitude E4300 Disk Drive Replacement: stap 5, afbeelding 1 van 2 Dell Latitude E4300 Disk Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  6. Dell Latitude E4300 Disk Drive Replacement: stap 6, afbeelding 1 van 1
    • Lift the keyboard panel to separate the component from the rest of the device.
  7. Dell Latitude E4300 Disk Drive Replacement, Disk Drive: stap 7, afbeelding 1 van 1
    • Once you have unscrewed all the screws, push in and slide out the disk drive from the device.
Conclusie
Cristal Blanco
73 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 471
