Ga door naar hoofdinhoud
Dell Latitude D830 Keyboard Replacement
Wat je nodig hebt
  1. Dell Latitude D830 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Orient the laptop so that the back is facing you.
    • With a phillip's head screwdriver, remove the two screws on the back corners of the laptop.
  2. Dell Latitude D830 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over, with the opening still facing up.
    • With a phillip's head screwdriver remove the two screws in the upper two corners.
  3. Dell Latitude D830 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Open the laptop up. Displaying the keyboard and screen.
    • Take a spudger and insert it under the left edge of the panel between the keyboard and screen.
    • Use the spudger to pry under the panel.
  4. Dell Latitude D830 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Place the spudger under the middle of the panel and use it to pry the panel off.
  5. Dell Latitude D830 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Place the spudger under the right side of the panel and use it to pry the panel off.
    • For additional help the spudger can be placed around the edge of the panel and used to pry it off.
  6. Dell Latitude D830 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • After you have the panel popped out, then you must pull the screen up as shows in the picture.
  7. Dell Latitude D830 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • The screen will only be connected by the wiring.
    • Take the screen and gently place it on the table as shown in the picture.
    • Now you must remove the three screws highlighted in the picture.
  8. Dell Latitude D830 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • After removing the three screws, slide the keyboard out so the mainframe of it is loose.
    • The a component still attached at the bottom.
  9. Dell Latitude D830 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • The highlighted item should be the only component holding the keyboard on.
  10. Dell Latitude D830 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Where the rectangle is, there is a silver lever that you must push back.
    • Then where the circle is on the photo, you must take the spudger and push in.
    • This will then pop the white clip off and the keyboard will be free.
  11. Dell Latitude D830 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • The keyboard is now completely detached, and is ready to be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 814
