Ga door naar hoofdinhoud
Dell Latitude D830 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude D830 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the laptop so the opening is facing you.
  2. Dell Latitude D830 Battery Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over, so the opening is still facing you.
  3. Dell Latitude D830 Battery Replacement: stap 3, afbeelding 1 van 1
    • Place finger/ thumb on the slide button, then push the button forward
    • This unlocks the battery.
  4. Dell Latitude D830 Battery Replacement: stap 4, afbeelding 1 van 1
    • Place finger/thumb under the ledge.
  5. Dell Latitude D830 Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift up the ledge, this allows the battery to be removed.
  6. Dell Latitude D830 Battery Replacement: stap 6, afbeelding 1 van 1
    • The battery is now removed.
  7. Dell Latitude D830 Battery Replacement: stap 7, afbeelding 1 van 1
    • To insert a new battery, orient the battery with the battery opening.
  8. Dell Latitude D830 Battery Replacement: stap 8, afbeelding 1 van 1
    • Insert the new battery with the left side being placed in first.
    • Press the new battery down until a "click" is heard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 397
