Ga door naar hoofdinhoud
Dell Latitude D630 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Latitude D630 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Wireless Card Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Latitude D630 Wireless Card Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Latitude D630 Wireless Card Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 Wireless Card Replacement: stap 5, afbeelding 1 van 2 Dell Latitude D630 Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 Wireless Card Replacement: stap 6, afbeelding 1 van 2 Dell Latitude D630 Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 Wireless Card Replacement, Wireless Card: stap 7, afbeelding 1 van 1
    • Remove the black and white cables on the wireless card with the tweezers by pulling upward.
    • The black has already been removed in the image to show before and after.
  8. Dell Latitude D630 Wireless Card Replacement: stap 8, afbeelding 1 van 1
    • Push on the tabs indicated in the picture until the card pops up slightly then pull the card out at an angle.
    How do You connect a card with three posts ?
    Chuck Hendricks - Antwoord
Conclusie
To reassemble your device, follow these instructions in reverse order with your new wireless card.
5 andere personen hebben deze handleiding voltooid.
Jon Amireh
1.696 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-1, Johann Winter 2013 Lid van Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 Leden
10 handleidingen geschreven
2 opmerkingen
1) You don't have to disconnect the keyboard cable to replace the WiFi card.
2) You may have three wires connected to the wifi card, disconnect all three
3) If your new wifi card has three sockets the grey lead heading off towards the front of the machine is for the middle socket; it has a plastic wrapper that can be slid off.
Robert de Bath - Antwoord
What type of Wi-Fi card is needed to be ordered to make it dual-band AC compatible?
Jake Brown - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 10,822
