Ga door naar hoofdinhoud
Dell Latitude D630 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Latitude D630 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Latitude D630 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Savi Chavan
979 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-4, Cichon Spring 2014 Lid van UMass Dartmouth, Team 1-4, Cichon Spring 2014
UMASSD-CICHON-S14S1G4
3 Leden
1 handleiding geschreven
4 opmerkingen
Dell latitude 2RHczd1
C Chandler - Antwoord
I appreciate the guide my good sir. Very helpful.
Matt Erti - Antwoord
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 15,325
