Ga door naar hoofdinhoud
Inleiding
Introduction
The hard drive is where you store permanent files on your laptop. If your hard drive is damaged and does not operate properly any more, or you simply want a larger and/or faster one, you can replace it with a new one.
This guide will teach you
  1. Where the Hard Drive is located
  2. how to remove safely
  3. Tools needed to complete the replacement
Onderdelen
Geen onderdelen opgegeven.
  1. Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Using two index fingers, slide the battery latches outward.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Position the closed laptop upside down. Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive. Do not unscrew this screw!
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  5. Place thumb on the hard drive cover and get a firm grip.
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  6. Unscrew the screw on the right side to remove cover. Slide cover off.
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Savi Chavan
800 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-4, Cichon Spring 2014 Lid van UMass Dartmouth, Team 1-4, Cichon Spring 2014
UMASSD-CICHON-S14S1G4
3 Leden
1 handleiding geschreven
Dell latitude 2RHczd1
C Chandler - Antwoord
Thank You Sir !
Bartłomiej Be - Antwoord
I appreciate the guide my good sir. Very helpful.
Matt Erti - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 10
Afgelopen 30 Dagen: 36
Altijd: 12,400
