Inleiding
Introduction
The hard drive is where you store permanent files on your laptop. If your hard drive is damaged and does not operate properly any more, or you simply want a larger and/or faster one, you can replace it with a new one.
This guide will teach you
- Where the Hard Drive is located
- how to remove safely
- Tools needed to complete the replacement
Wat je nodig hebt
Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
Turn the laptop over so its bottom is facing you.
Position the closed laptop upside down.
Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
Do not unscrew this screw!
17 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Dell latitude 2RHczd1
Thank You Sir !
