Ga door naar hoofdinhoud
Dell Latitude D620 Keyboard Replacement
Wat je nodig hebt
  1. Dell Latitude D620 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Mera display ka masla hai
    manaqib arif - Antwoord
  2. Dell Latitude D620 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell Latitude D620 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell Latitude D620 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Latitude D620 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Latitude D620 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
Conclusie
10 andere personen hebben deze handleiding voltooid.
Miguel Wong
556 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-35, Regan Spring 2010 Lid van Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Leden
4 handleidingen geschreven
Één opmerking
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 16,758
