Ga door naar hoofdinhoud
Dell Latitude D620 Hard Drive Replacement
Wat je nodig hebt
    • First, as always, power down the laptop and remove the battery., This can be done by pulling the two tabs above the battery and then simply pulling out the battery.
  1. Dell Latitude D620 Hard Drive Replacement, Unscrew the drive bay: stap 2, afbeelding 1 van 1
    • Now, remove the two drive screws, located in the bottom right of the laptop. These are helpfully labeled with a cylindrical hard drive icon.
  2. Dell Latitude D620 Hard Drive Replacement, Removing the drive bay: stap 3, afbeelding 1 van 1
    • Now, simply pull the hard drive out
  3. Dell Latitude D620 Hard Drive Replacement, Removing the drive from its cage: stap 4, afbeelding 1 van 1
    • Now, remove the drive from its cage by removing the single screw holding it in. See the picture for help
Conclusie
To reassemble your device, attach your drive to the bay and follow these instructions in reverse order.
5 andere personen hebben deze handleiding voltooid.
James Martin
231 Reputatie
1 Handleiding geschreven
2 opmerkingen
can i install 1 tr wd sshd 2.5 inch on dell d620?
does it support it??
please answer my quastion.
pouranvary@gmail.com
mohammad - Antwoord
can my dell d620 support 1 tr sshd?
does it support 1 tr hard?
please answer my quastion:
mohammad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 2,116
