Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Unscrew the top portion of the keyboard using a #00 screwdriver
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Once keyboard is out of the case, lay it face-down on the track pad
Using a small spudger, pull back on the black bar to release the blue lever
Pull up on the metal bar connected to the socket to detach the ribbon cable
Press in the tab on the bottom right side of the CD drive
10 andere personen hebben deze handleiding voltooid.
