Ga door naar hoofdinhoud
Dell Latitude D620 CD Drive Replacement
Wat je nodig hebt
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 CD Drive Replacement: stap 2, afbeelding 1 van 3 Dell Latitude D620 CD Drive Replacement: stap 2, afbeelding 2 van 3 Dell Latitude D620 CD Drive Replacement: stap 2, afbeelding 3 van 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 CD Drive Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 CD Drive Replacement: stap 4, afbeelding 1 van 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 CD Drive Replacement: stap 5, afbeelding 1 van 2 Dell Latitude D620 CD Drive Replacement: stap 5, afbeelding 2 van 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 CD Drive Replacement: stap 6, afbeelding 1 van 2 Dell Latitude D620 CD Drive Replacement: stap 6, afbeelding 2 van 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 CD Drive Replacement: stap 7, afbeelding 1 van 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: stap 8, afbeelding 1 van 2 Dell Latitude D620 CD Drive Replacement, CD Drive: stap 8, afbeelding 2 van 2
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
  9. Dell Latitude D620 CD Drive Replacement: stap 9, afbeelding 1 van 1
    • Gently pull the tab to remove the disk tray.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Ivan
194 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-35, Regan Spring 2010 Lid van Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 119
Altijd: 8,885
