Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the 3.9 mm Phillips #1 screw from the battery compartment.
Locate the laptop battery release button lock
Push the battery release in the direction of the arrow, and pull upward.
Use an opening tool or flat tool to remove the plastic cover above the keyboard.
Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
Using an opening tool, carefully release the keyboard from the case.
Carfully lift the key board.
Pull on the blue tab to unplug the keyboard.
Remove the two 3.9mm Philips #1 screws from the case.
Remove the sixteen 3.9mm Philips #1 screws from the back.
Turn the computer over. Using an opening tool seperate the top cover from the rest of the frame.
Remove the 3.9 mm Philips #1 screw.
Unplug the fan cable.
Lift fan out of compartment to remove the fan.
