Ga door naar hoofdinhoud
Dell Latitude D600 Wireless WiFi Card Replacement
Wat je nodig hebt
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: stap 2, afbeelding 1 van 2 Dell Latitude D600 Wireless WiFi Card Replacement: stap 2, afbeelding 2 van 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: stap 4, afbeelding 1 van 1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: stap 5, afbeelding 1 van 1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: stap 6, afbeelding 1 van 2 Dell Latitude D600 Wireless WiFi Card Replacement: stap 6, afbeelding 2 van 2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: stap 7, afbeelding 1 van 2 Dell Latitude D600 Wireless WiFi Card Replacement: stap 7, afbeelding 2 van 2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Conclusie
6 andere personen hebben deze handleiding voltooid.
Joseph
1.497 Reputatie
5 handleidingen geschreven
Één opmerking
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 2,633
