Ga door naar hoofdinhoud
Dell Latitude D600 RAM (Main Memory) Replacement
Wat je nodig hebt
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: stap 1, afbeelding 1 van 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: stap 2, afbeelding 1 van 2 Dell Latitude D600 RAM (Main Memory) Replacement: stap 2, afbeelding 2 van 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): stap 4, afbeelding 1 van 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): stap 4, afbeelding 2 van 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: stap 5, afbeelding 1 van 3 Dell Latitude D600 RAM (Main Memory) Replacement: stap 5, afbeelding 2 van 3 Dell Latitude D600 RAM (Main Memory) Replacement: stap 5, afbeelding 3 van 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: stap 6, afbeelding 1 van 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: stap 7, afbeelding 1 van 3 Dell Latitude D600 RAM (Main Memory) Replacement: stap 7, afbeelding 2 van 3 Dell Latitude D600 RAM (Main Memory) Replacement: stap 7, afbeelding 3 van 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: stap 8, afbeelding 1 van 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Conclusie
6 andere personen hebben deze handleiding voltooid.
Joseph
1.497 Reputatie
5 handleidingen geschreven
Één opmerking
Almost perfect: easy; clear;
Herman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 19
Altijd: 2,842
