Wat je nodig hebt
The computer has two memory slots, DIMM A and DIMM B. DIMM A is located on top of the computer under the keyboard, and DIMM B is located on the bottom of the computer under the memory module cover.
DIMM A holds the basic memory module as configured from the factory. If you did not order additional memory, DIMM B is empty. Generally, if you add memory, you use DIMM B. If you are upgrading memory, you may need to install memory in DIMM A and DIMM B, depending on the extent of the upgrade.
Ground yourself by touching one of the metal connectors on the back of the computer.
If you leave the area, ground yourself again when you return to the computer.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector.
Ground yourself and install the new memory module by aligning the notch in the module edge connector with the tab in the connector slot.
Slide the module firmly into the slot, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
Insert or replace the keyboard, hinge cover, and battery on the computer respectively.
If you're willing to replace or install the memory module/chip in the DIMM B connector, only insert or replace the keyboard and hinge cover.
Turn the computer upside-down, loosen the captive screw on the memory module cover (see image), and remove the cover.
If you are replacing a memory module, remove the existing module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Insert memory modules at a 45-degree angle to avoid damaging the connector. If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
Insert the battery into the battery bay, or connect the AC adapter (charger) to your computer and an electrical outlet.
Turn on the computer.
