Wat je nodig hebt
1. unplug laptop
2. remove battery
3. remove screw
Remove disk drive by pressing in the pull mechanism, causing it to extend outwards, then use the pull handle to pull out disk drive.
The middle part of my power connector had sheared away from its solder points on the motherboard.
I had to use a bit of flux, but I managed to re-tin all three contact point on the motherboard, as well as the pins in the connector.
I re-soldered the whole thing and used my trusty hot glue gun to encase the whole connector to prevent it from happening again anytime soon.
6 andere personen hebben deze handleiding voltooid.
