Ga door naar hoofdinhoud
Dell Latitude D430 Wireless Adapter Replacement
Wat je nodig hebt
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: stap 1, afbeelding 1 van 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: stap 1, afbeelding 2 van 3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: stap 1, afbeelding 3 van 3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: stap 2, afbeelding 1 van 2 Dell Latitude D430 Wireless Adapter Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: stap 3, afbeelding 1 van 1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: stap 4, afbeelding 1 van 3 Dell Latitude D430 Wireless Adapter Replacement: stap 4, afbeelding 2 van 3 Dell Latitude D430 Wireless Adapter Replacement: stap 4, afbeelding 3 van 3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: stap 5, afbeelding 1 van 2 Dell Latitude D430 Wireless Adapter Replacement: stap 5, afbeelding 2 van 2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: stap 6, afbeelding 1 van 1
    • Pull the wireless adapter out away from where it was connected.
Conclusie
Parker Wiley
382 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 511
