Inleiding
This is a Headphone Jack replacement guide for a Dell Latitude 9510 USB. Ensure the jack is fully inoperable before replacement. To replace jack, follow steps below. Use caution to ensure no further damage to hardware.
Wat je nodig hebt
Flip the device so that the base plate is facing you.
Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
