Ga door naar hoofdinhoud
Dell Latitude 9510 Fan Replacement
Wat je nodig hebt
  1. Dell Latitude 9510 Fan Replacement, Base Panel: stap 1, afbeelding 1 van 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Fan Replacement: stap 2, afbeelding 1 van 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Fan Replacement, Speakers: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Fan Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  5. Dell Latitude 9510 Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  6. Dell Latitude 9510 Fan Replacement: stap 6, afbeelding 1 van 1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
Conclusie
Adam Sholar
243 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 141
