Ga door naar hoofdinhoud
Dell Latitude 9510 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude 9510 Battery Replacement, Base Panel: stap 1, afbeelding 1 van 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: stap 2, afbeelding 1 van 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: stap 4, afbeelding 1 van 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
Conclusie
David Cauley
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 51
Altijd: 761
