Inleiding
This is an in depth instruction manual to replace the baseplate for your Dell Latitude 9510 laptop. The baseplate, also known as a backplate, is used to protect the inner electronics of the computer from small drops and spills. This is a common replacement due to dropping the device or improperly removing the backplate making it break.
Wat je nodig hebt
Flip the device so that the base plate is facing you.
Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
