Ga door naar hoofdinhoud
Dell Latitude 7420 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude 7420 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Latitude 7420 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Latitude 7420 Battery Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Latitude 7420 Battery Replacement: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: stap 5, afbeelding 1 van 2 Dell Latitude 7420 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Hong Lee
208 Reputatie
1 Handleiding geschreven
Één opmerking
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 76
Afgelopen 30 dagen: 369
Altijd: 11,099
