Ga door naar hoofdinhoud
Dell Latitude 7390 SSD Replacement
Wat je nodig hebt
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 7390 SSD Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 7390 SSD Replacement: stap 2, afbeelding 3 van 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: stap 3, afbeelding 1 van 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: stap 4, afbeelding 1 van 2 Dell Latitude 7390 SSD Replacement: stap 4, afbeelding 2 van 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: stap 5, afbeelding 1 van 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: stap 6, afbeelding 1 van 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: stap 7, afbeelding 1 van 3 Dell Latitude 7390 SSD Replacement: stap 7, afbeelding 2 van 3 Dell Latitude 7390 SSD Replacement: stap 7, afbeelding 3 van 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): stap 9, afbeelding 1 van 1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: stap 10, afbeelding 1 van 1
    • Remove the SSD card from under the silver plate.
Conclusie
Thomas Pryor
86 Reputatie
1 Handleiding geschreven
Clemson, Team 1-4, Hunter Spring 2022 Lid van Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 62
Altijd: 2,967
