Ga door naar hoofdinhoud
Dell Latitude 7390 Fan Replacement
Wat je nodig hebt
  1. Dell Latitude 7390 Fan Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Fan Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 7390 Fan Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 7390 Fan Replacement: stap 2, afbeelding 3 van 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Fan Replacement: stap 3, afbeelding 1 van 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Fan Replacement: stap 4, afbeelding 1 van 2 Dell Latitude 7390 Fan Replacement: stap 4, afbeelding 2 van 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Fan Replacement: stap 5, afbeelding 1 van 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Fan Replacement, Battery: stap 6, afbeelding 1 van 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Fan Replacement: stap 7, afbeelding 1 van 3 Dell Latitude 7390 Fan Replacement: stap 7, afbeelding 2 van 3 Dell Latitude 7390 Fan Replacement: stap 7, afbeelding 3 van 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Fan Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 Fan Replacement, Fan: stap 9, afbeelding 1 van 1
    • Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
  10. Dell Latitude 7390 Fan Replacement: stap 10, afbeelding 1 van 1
    • Use tweezers or your fingers to disconnect the fan connector.
  11. Dell Latitude 7390 Fan Replacement: stap 11, afbeelding 1 van 1
    • Remove the fan from the case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Glennjay Elayda
246 Reputatie
2 handleidingen geschreven
Clemson, Team 1-4, Hunter Spring 2022 Lid van Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 59
Altijd: 2,451
