Ga door naar hoofdinhoud
Dell Latitude 5521 Solid-State Drive Replacement
Wat je nodig hebt
  1. Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: stap 1, afbeelding 1 van 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: stap 1, afbeelding 2 van 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: stap 1, afbeelding 3 van 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: stap 2, afbeelding 1 van 2 Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: stap 2, afbeelding 2 van 2
    • Locate the solid-state drive.
    • Remove the screw on the right side of the drive.
    • After remove the screw, the drive will "pop-up" to approximately a 45% angle. Pull the drive straight out in accordance with the angle.
    • Static electricity is always a danger. Take precautions to protect the drive while, and once, it is removed.
Conclusie
Michael Engle
461 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 1,180
