Ga door naar hoofdinhoud
Dell Latitude 5480 Power Jack Replacement
Wat je nodig hebt
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 5480 Power Jack Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 5480 Power Jack Replacement: stap 2, afbeelding 3 van 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: stap 3, afbeelding 1 van 2 Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: stap 3, afbeelding 2 van 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: stap 4, afbeelding 1 van 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: stap 4, afbeelding 2 van 3 Dell Latitude 5480 Power Jack Replacement, Power Jack: stap 4, afbeelding 3 van 3
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: stap 5, afbeelding 1 van 3 Dell Latitude 5480 Power Jack Replacement: stap 5, afbeelding 2 van 3 Dell Latitude 5480 Power Jack Replacement: stap 5, afbeelding 3 van 3
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: stap 6, afbeelding 1 van 1
    • Lift the entire charging port assembly up and out of the chassis.
Conclusie
Valencia Vidrine
457 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 72
