Wat je nodig hebt
Unscrew the bottom from the frame.
There are 8 captive screws.
Use the pick to pry to back off releaseing the clips that hold it on.
There are 2 screws holding it closed. They are not captive.
You can detach the battery if you want. Just pull up on the battery cable using the pull tab.
Remove the ssd holder by lifting upon the back or middle then pull it towards you or move it to the side.
Pull ssd out and replace it.
Conclusie
