Inleiding
Follow this guide to remove the base of your dell latitude.
Wat je nodig hebt
Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
Carefully lift and remove the base cover.
Bijna klaar!
Conclusie
