Ga door naar hoofdinhoud
Dell Latitude 3500 Power Button Board Replacement
Wat je nodig hebt
  1. Dell Latitude 3500 Power Button Board Replacement, Remove screws: stap 1, afbeelding 1 van 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 Power Button Board Replacement, Separate bottom cover and palmrest: stap 2, afbeelding 1 van 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 Power Button Board Replacement, Disconnect and Remove Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 Power Button Board Replacement, Disconnect Surrounding Connections from System Fan: stap 4, afbeelding 1 van 1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 Power Button Board Replacement, Remove Fan Screws: stap 5, afbeelding 1 van 1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 Power Button Board Replacement, Disconnect Ribbon Cable: stap 6, afbeelding 1 van 1
    • Insert wisdom here.
  7. Dell Latitude 3500 Power Button Board Replacement, Lift Left-Side Hinge: stap 7, afbeelding 1 van 1
    • 2 screws total
  8. Dell Latitude 3500 Power Button Board Replacement, Remove Board: stap 8, afbeelding 1 van 1
    • 2 screws total
Conclusie
Jake
1.300 Reputatie
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 43
