Ga door naar hoofdinhoud
Dell Latitude 3190 Power Switch Board Replacement
Wat je nodig hebt
  1. Dell Latitude 3190 Power Switch Board Replacement, Base Cover: stap 1, afbeelding 1 van 2 Dell Latitude 3190 Power Switch Board Replacement, Base Cover: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Power Switch Board Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 2, afbeelding 3 van 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Power Switch Board Replacement, Battery: stap 3, afbeelding 1 van 1
    • Locate the battery.
  4. Dell Latitude 3190 Power Switch Board Replacement: stap 4, afbeelding 1 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 4, afbeelding 2 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Power Switch Board Replacement: stap 5, afbeelding 1 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 5, afbeelding 2 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Power Switch Board Replacement: stap 6, afbeelding 1 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 6, afbeelding 2 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 6, afbeelding 3 van 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: stap 7, afbeelding 1 van 2 Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: stap 7, afbeelding 2 van 2
    • Disconnect the power switch cable from the motherboard.
  8. Dell Latitude 3190 Power Switch Board Replacement: stap 8, afbeelding 1 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 8, afbeelding 2 van 3 Dell Latitude 3190 Power Switch Board Replacement: stap 8, afbeelding 3 van 3
    • Remove the two 3 mm screws that secure the power switch board on the computer.
  9. Dell Latitude 3190 Power Switch Board Replacement: stap 9, afbeelding 1 van 2 Dell Latitude 3190 Power Switch Board Replacement: stap 9, afbeelding 2 van 2
    • Lift the power switchboard away from the computer.
Conclusie
Haley Smith
305 Reputatie
2 handleidingen geschreven
Gateway, Team 1-5, Saknee Fall 2021 Lid van Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 392
