Inleiding
If you need to replace or upgrade your M.2 SSD for the Dell Latitude 3190, follow this guide.
Before starting this repair, power off your device and unplug from the charger.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
Bijna klaar!
Conclusie
