Inleiding
Follow this guide if the keyboard in your Dell Latitude 3190 has stopped functioning.
Make sure your device is powered off and unplugged from external power before beginning the repair.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Use the spudger to release the small black tab locking down the connector by lightly pushing up on it.
Disconnect the keyboard cable from the connector on the system board.
